Atwood hydro flame model 2334. Furnace did not appear to be heating properly, came home and washed FW then tried to start it again, but with no success, removed outside cover and found som water insid...
Another thing on Dinosaur boards in a separate ground wire on some. This prevents larger current flows from going through circuit board components. Dinosaurelectronics.com and available on Amazon. OP: remove the circuit board and lay it out in the sun for a few hours. I know it is wintertime down-under! Socket should be 1/4 inch US. Think that is 6.5 MM
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
