dougrainer
Feb 06, 2022Nomad
CharlesinGA wrote:
Weld the tank. that heater is no longer made in that size and shape. The Texas deep freeze of a year ago went thru all of the stocks of the old Atwood design.
Suburban does make a Atwood compatible replacement but its a Suburban with its steel tank and I would not want one.
The heater disassembles rather easily and you only need a couple of sleeves that fit the outside of the flame tubes, They press in and easily done with a piece of large PVC pipe as a driver.
The H in the model number GHC6A-10E is what tells you it is a heat exchanger model.
Charles
After 43 years as an RV tech, I don't understand WHY you would not want a Suburban Water Heater. It has a porcelain-lined, steel water heater tank. I would state that the rate of freezing and causing a destroyed inner tank is 10 to 1. 10 Atwoods for every 1 Suburban is about what I have experienced over the years. Granted, you cannot buy a Suburban replacement inner tank, but they are more forgiving in freezing weather than the Atwood Aluminum tank. Doug
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 07, 2025
