Breed1229
Mar 28, 2019Explorer
Atwood water heated will not stay running.
I’m hoping someone can help me out. I have an Atwood G6A-8E that will not stay running. I can turn it on when it’s cold and it will run for about 10 minutes. I have timed this. Occasionally it’s a but longer or a bit shorter, but about 10 minutes. Then it turns off and I get the fault light. If I turn it back on it will light and run for 5 seconds. Then if I let it cool it will start this all over. 10 minutes and then 5 seconds.
I have replaced the thermostat , the ECO, the igniter, the circuit board and I’m waiting on the valve body. Same thing.
I’ve cleaned all the connections and grounds. I’ve verified that the U tube is clear and that I have over 12 volts to the board and that the he bypass valve is in the proper position. Maybe the valve is broken? When it lights it runs nice and blue with just a slight roar.
Tonight I’m going to blow out the propane line to the heater just to be sure. I’m not really thinking that there will be an obstruction but what do I have to loose.
What am I missing? I’m sure it’s somthing silly. Racing season is here and I really would like a hot shower after a sticky day at the track.
Thank you in advance.
