โJul-20-2019 11:50 AM
โJul-21-2019 02:45 PM
โJul-21-2019 10:19 AM
Old-Biscuit wrote:
BAD circuit board
Atwood changed vendors back in 2016 (??) to a different Chinese vendor and got a slew of defective circuit boards by the 1000's
They were in Atwood/Dealer/Aftermarket stocks
Sept 2018 they swapped out the defective for another vendor (Atwood/Dealer)---some Aftermarkets still have them in stock/on shelf.
Atwood was replacing for FREE.
Check the Vendor/Bar Code.....if Zhongding. Bad board
โJul-20-2019 07:30 PM
John Wayne wrote:
I've been having problems with mine also and down loaded a list of tests for the pc board. The first test is to make sure you have a good ground went out unscrewed the ground wire retightened it problem solved. Give it a try.
โJul-20-2019 07:28 PM
Old-Biscuit wrote:
BAD circuit board
โJul-20-2019 05:00 PM
โJul-20-2019 03:20 PM
โJul-20-2019 03:13 PM
โJul-20-2019 11:59 AM
