MrWizard
Oct 11, 2022Moderator
You have a 30amp rv,
But what is the wattage rating of the generator, make and model # would be helpful, if its over 4000w, and built in, it has (2) circuit breakers on the generator and is wired to the second lesser rsted 20 smp breaker, you are bypassing that breaker snd powering everything from the breaker meant for just the appliances and outlets
Just because you can't see it, doesn't mean it isn't tripped,you should manually reset both breakers that are on the generator, posting make model and year of the RV might help, someone will know if there is switch you missed, hidden in a closet, or under a cabinet, maybe in the bedroom,
I once had a Komfort Brand motorhome with a switch in the bedroom Closet to change the a/c from shore power to generator power
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 25, 2025
