StewB's avatar
StewB
Awning Cleaning Solution
In the past I found a recipe on here for a awning cleaning solution. I have searched but cannot find it. Does someone know it? You mix it up, bleach, detergent and hot water and spray it on the awning then roll up for a while. I don't remember the amount of each ingredient.
Thanks
  • I just spray the fabric with one of those kitchen/bathroom cleaners that has some bleach in it ... roll the fabric up for 1/2 hr and then rinse off. Been doing that for almost 30 yrs. Just make sure you use old nasty shirt because any water droplets will likely bleach your shirt.
  • Beach might weaken the fabric. i use a mixture of Dawn and Murphy Soap. Or you can use just one.
  • ppine's avatar
    ppine
    Detergent with a small amount of bleach added to it works fine.
  • I use Miracle Mist RV cleaner. Spray it on, let it sit a couple minutes, then hose it off.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
