CharlesinGA
May 03, 2021Explorer
I pulled out the awning about a foot from retracted, taped the ratchet lever so it could not get bumped, removed the upper bracket from the front so the fabric could be slid out/in the channel on the side of the trailer. Removed the lock screw that holds it in the channel, took the arms loose at the bottom and walked the fabric out of the channel, then we laid the awning arms on sawhorses, with the bottom of the arms resting on the ground, and unwrapped the fabric from the roller. Marked the roller for what went where, and fed the new one into the roller (end cap was manufactured with a notch for the fabric to pass thru, and the valance was pushed into the groove and we drilled a hole in the end cap and pushed the plastic into the groove on top of the valance. When that was done, we wrapped the fabric around the roller, leaving about the same amount hanging off the roller and then we walked the new fabric in the channel on the trailer, carrying the arms vertical like we had removed it. Snapped the arms in the lower brackets, reinstalled the upper front bracket with lots of sealer, removed the tape and pulled the awning out and then in several times to seat it. ran a screw back into the channel to hold the fabric in place and done. Never touched the springs.
A&E 8500
Charles
A&E 8500
Charles
