Iraqvet05's avatar
Iraqvet05
axle seal questions
I need to buy axle seals from my 3500 lb axles and from what I can tell, I need the Dexter 010-004-00 (K71-303-00). I believe they are single lip seals (non EZ Lube hubs) but most sources I found have a high shipping rate or list a double lip seal. Can I use a double lip seal in place of a single lip? Amazon sells a Lippert seal I can get with Prime shipping. Any issues with using a Lippert seal on a Dexter axle if the seal outer and inner dimensions are the same?
  • I would actually measure your axle diameter before ordering.
    Difficult to be sure you're getting the right one otherwise.
    In my case, it turned out that my Al-Ko 5200# axles come in two different diameters, and I had ordered the wrong seals.
    Luckily the right seals were available at a local shop (at 3x the price).
  • walk in to a auto parts store they should stock them, and I like a double lip better.
    Yes, you can use any seal that has the dimensions that fit your hub and axle dimensions.
    BTW; I don't think it would hurt anything if you did used a double lip seal over the single. JMHO
  • Can I use a double lip seal in place of a single lip?
    Yes. Double lip seals help seal the dirt and grime out as well as keeping the grease in.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
