puttd's avatar
puttd
back up camera won't work in reverse
I have a back up camera that shows up on a Jensen 212T monitor in the dash. If I put the motorhome in reverse, I get the message,
"no input". Works just fine going forward but would be really nice to have it work for reverse since its a back up camera. :S. I have gone through the menu and don't see something that would make it only work moving forward.
Thanks
  • How many cameras ?
    What camera is on while driving forward ..side view...rear view
    Maybe the rear view camera is dead
  • You can also wire them to stay on when your driving forward too!
  • You have rear view while driving forward, but it goes blank when you shift to reverse
    That msg means ...no camera input attached to the secondary input
    The signal on the reverse switch
    Shift means it wired to the backup lights ..as sensor mode but no camera is attached
    You have two choices moved the camera aka video signal to the secondary input and have video in reverse but not while driving
    Or disconnect the Jensen from the backup signal
    Find the manual and disconnect that wire and the monitor should not switch signals
    There is an easy test
    Find the fuse for the backup lights and remove it
    Then switch to reverse and see if the display stays on
    Obviously you want to keep your back up lights but do this as a, test in the driveway
  • If you do not have a manual, here is a link to one:
    Read about Camera Triggers and Priority:
    Oops, the forum link tool isn't working for me.
    You'll need to copy/paste.
    http://www.jensenrvdirect.com/downloads/dl/file/id/574/jrv212t_owners_manual.pdf
  • Obviously you have to switch the pos and neg wires on its terminals! :)
Having RV issues? Connect with others who have been in your shoes.24,256 PostsLatest Activity: May 22, 2025
