BradKW's avatar
BradKW
Backup camera with two monitors?
Hello! Long time ghoster, first time poster...
I'm in process of converting a box truck to an RV and would really like a camera system that allows for 3 cameras and will display on two separate monitors.
I want to obviously see backup and side cam while driving, but would also like to use cameras as security and surveillance when I'm in back camper. At this point, DVR isn't necessary, but might be nice to have. I will have a PC in back, so something that feeds into a PC for 2nd display would be cool if it exists.
Most of my searches that meet criteria end up being home systems that are POE (power over ethernet, 48v). So any links, suggestions or recommendations would be much appreciated!
  • One that I have is an Esky X000BJDU21 with 7 IR LEDs. It is connected through an Esky Wireless Transceiver.
    It came from Amazon not Ebay but the same item is probably on Ebay..
  • Joe417 wrote:
    There are hundreds of different cameras and systems.(backup systems)
    Sounds like what you are looking for needs to also be IR compatible.
    Indeed there are hundreds...my online shopping efforts end each time moments before my head explodes ;)
    Curious what you mean by IR compatible? Most cameras have IR for night vision, but IR for wireless connectivity isn't something I've seen. Perhaps due to it being outside the visible light spectrum...
  • I didn't know Ethernet could provide 48 volts. I'll have to read about that.
    Search in the automotive hardware on ebay. They are 12 volt. There are hundreds of different cameras and systems.(backup systems)
    Most I've seen put out standard video(NTSC)that can be captured with a compatible software.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
