Hemling's avatar
Hemling
Bad thermostat?
2017 Keystone Sprinter 33bh. Single roof AC unit, Coleman three button thermostat keeps cutting out. Sometimes runs for days, sometimes shuts off randomly three or four times in a row. Sometimes entire thermostat goes dark, sometimes just kills fan and AC. Will do this randomly on fan or AC. Is this a common problem? Thermostat box seems very flimsy and cheap.
  • We are 1700 miles from home yet, so I'm going to limp it along but I'm thinking of taking it apart at out last stop to see if there's a loose connection or whatnot. I need to address a couple other minor issues at the end of our trip also.
  • islandvagabonds wrote:
    Some of the RVP thermostsats were suseptible to RF inerference from flourescent lights and cell phone chargers. The Tstats wouold just blank out to 0000.
    Depower your tsat and any of the above then restart the tsat to see if that is the issue. Been there done that.
    Good luck
    Bob
    These RVP tstats are the old Zone Control tstats. He has a newer that is not subject to RF problems. Doug
  • Some of the RVP thermostsats were suseptible to RF inerference from flourescent lights and cell phone chargers. The Tstats wouold just blank out to 0000.
    Good luck
    Bob
  • The reason I keep coming back to the thermostat box is because when it acts up sometimes the entire display goes blank, like it's not getting power at all. Then, randomly, it will come back on again and I can turn the AC or fan back on. Sometimes the digital display stays on and it just licks off like it's reached the target temperature. Sometimes the screen flickers like a loose connection. I'm thinking of just taking it apart to see if there's something loose inside. Also it seems like this isn't a very expensive unit, the same one lists on Amazon/eBay between $50-$100.
  • I can remove the digital thermostat from the wall and see there are 7 or 8 wires going into it. They all look to be secure at least where the wires fit into the plug in harness on the back of the box. It is the Coleman Airxcel unit. Has two triangular arrow buttons and one longer rectangular button below it. Not a touchscreen. Where on my camper are the locations that I should check for a loose connection? The camper is three years old and I've never had to dig into anything like that yet.
  • Sorry, I had Dometic on my mind. But, same things. You seem to have the LCD Coleman(RVP) wall tstat? Verify wiring is secure at the tstat and also at the roof AC control board. 12 volt power to the system depends on the OEM and if they run 12 volts direct to the AC system or if the use the Furnace 12 volt wire to power it. Doug
    PS, There is no common failure of this tstat.
  • could be a loose wire .I,d check the box where the ac and power lines come together, sometimes those wire nut connectors come loose.just a guess.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
