rockwind1's avatar
rockwind1
Feb 23, 2019
BAD?? using generator and honda eu2000 at the same time.
2007 attitude toyhauler 33'
i have a honda 2000 that i keep plugged into the shore power input on the trailer and i use it most of the time. but every now and then i need to use the microwave or toaster so i usually fire up the onboard generator but then i have to go outside and turn off the honda cause i am not sure what would happen to the electrical system if they were both running.
however, if i am plugged into shore power and then i turn on the onboard generator, i don't think anything happens.
so question is, can i keep the honda running while also running the onboard generator? thanks in advance.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
