Ava
Sep 06, 2015Explorer
Use a basic volt/ ohm meter and check the voltage. It will read the voltage either way but will show a negative sign in front of the voltage if you have the red lead on the ground.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
