โOct-25-2013 09:10 PM
โOct-28-2013 09:56 AM
โOct-28-2013 09:44 AM
BFL13 wrote:Yes, I have an inverter. I have now separated all the batteries and am going to take them to Les Swab tire center to have them load tested.
Does the OP have an inverter in the mix?
Even with nothing on the batteries at all except the big inverter, I get a good spark at the battery post when doing the inverter's wires. I gather that is the inverter's capacitor(s)
โOct-28-2013 09:19 AM
โOct-28-2013 08:32 AM
โOct-28-2013 07:57 AM
โOct-28-2013 07:44 AM
mena661 wrote:I have never let them go dead. I charge them with a generator or pull it out of the building and let the solar panels charge them.RJsfishin wrote:X2
I wonder how many times they were run stone dead, and for how long ??
โOct-28-2013 06:43 AM
RJsfishin wrote:X2
โOct-28-2013 05:31 AM
โOct-28-2013 04:35 AM
โOct-27-2013 06:43 PM
smkettner wrote:The 12 volt switch that supposedly turns off all the power was in the off position. This is a new trailer (1 year old) and am mystified by all this. It has been in the shop almost four months in our first year of ownership. I am having trouble finding competent people to work on it. I could go on for pages with all the stories and will stop here. I can build a house from the ground up but electrical and especially 12 volt I don't have a clue. Maybe I should take it to an auto electric shop as the RV folks damage the outside of our new trailer every time we take it in.
Spark = something is on. Just a matter of discovery.
โOct-27-2013 05:36 PM
โOct-27-2013 05:06 PM
smkettner wrote:I read the state of charge three days ago and it was 12.8 and is now 12.3. When I disconnected the negative cables, one threw a pretty good spark. This is with everything off.
Yes something is draining them or one is bad pulling down the rest.
Full 100% charge and then fully disconnect and separate for testing.
Should hold 12.8+ volts for at least a few weeks.
โOct-27-2013 03:36 PM
โOct-27-2013 02:56 PM
tvfrfireman wrote:tenbear wrote:I will check into this tool. I am pretty sure that the drain must be the hydraulic system as one other person with same brand has the same problem on the DRV forum. The only thing hooked to the battery is the hydraulic system. I don't understand why so many things are wired upstream of the 12 volt cut off switch.. Thanks for you response..
Time to invest in a clamp-on ammeter and see what the drain is.
โOct-27-2013 02:32 PM
