Slownsy
Oct 16, 2020Explorer
Batteries
I have 4 6V 260A Crown batteries. They are 5 years old and don’t like to charge op to good. After charging and disconnected only 12.69V, day after at 12.57v . Gravity of cells from 1275 to loves tat 1240. From my estimated at about 80% off the 520A from new ? Newer discharged to less than60% mostly less, but when out last had to use our generator for charging true my Magnum inverter charger, they were accepting a bit over 100A for a period before tapping down slowly. My wife do like to run microwave with inverter which draws about 150A, the most I have ever seen on the display was a bit below 200A draw. We have 600W of solar on roof charging tru a Tri-Metric 30A charger.
Normally discharge 1.3-1.4A so about 30A in 24 hours. Also when away running a inverter fridge etc use 75-100A in 24hours.
So my question is can I still expect reasonable use out of the batteries or do I have to replace fairly soon. Thanks Frank. I am in Australia by the way.
