BFL13
Oct 22, 2016Explorer II
Brain trouble here. :( I know that the controller allows twice the wattage of panels when batts are 24 vs 12.
I know that half the amps charge 24v batts the same as twice the amps do 12s. So if you do 24-24 at 8 amps DC output that is as good as doing 16 amps output with 24-12.
But where does it say you can have twice the wattage on the same set of batts by going 24 instead of 12, so you get the same amps---which is worth twice as much for recharging?
Please explain. I know I am having a problem here! :)
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
