โJul-29-2016 11:15 AM
โAug-01-2016 05:11 AM
Almot wrote:Joel_T wrote:
I emailed Bogart Eng questioning my habit on their SC2030 controller. We'll see.
If you want to be really thorough in this quest for the truth, then ask them what people here are talking about - controller and panels without battery.
Like this: "What happens if I connect SC2030 straight to panels with no battery and no Trimetric"?
They will probably tell you that this controller is not designed to be used without Trimetric. What Tri does, is "controlling the controller". It detects the battery voltage and adjust everything in controller. So, with the Tri in the picture the experiment won't be conclusive.
โJul-31-2016 08:34 PM
โJul-31-2016 02:00 PM
โJul-31-2016 01:20 PM
Joel_T wrote:
What's it matter whether it's panels or battery first?
โJul-31-2016 12:53 PM
โJul-31-2016 12:39 PM
โJul-31-2016 11:50 AM
โJul-31-2016 10:40 AM
pianotuna wrote:
Hi Joel,
For some controllers running without the battery connected may let out the magic blue smoke.Joel_T wrote:smkettner wrote:
No switch. My RV runs 24/365 on solar. And with 510 watts you should not have an issue. Off is fine too.
Always cut power from panels before you disconnect controller from battery.
What's the danger....overloading the controller? I have a fused breaker before and after the controller and shut the one off between controller and batteries occasionally so I can measure true panel output without the battery influence.
โJul-30-2016 10:10 PM
โJul-30-2016 09:20 PM
2oldman wrote:smkettner wrote:x2
Controller is designed to charge a battery not to be an open power supply. And when I pay $500 for a piece of equipment I try to go by the book. So read your manual..
My Outback controller manual is clear about connecting batteries first.LScamper wrote:I don't know, but that's extremely unlikely, unless one likes to keep one's batteries until they die.
Just wondering what happens if the battery fails in an open condition. Will it destroy the controller?..so I can measure true panel output without the battery influence.
I'm not sure why knowing the 'true panel output' sans batteries would be of any value.
โJul-30-2016 03:50 PM
โJul-30-2016 03:02 PM
โJul-30-2016 10:48 AM
smkettner wrote:x2
โJul-30-2016 10:37 AM
Joel_T wrote:My manual says so. I believe others do also. Controller is designed to charge a battery not to be an open power supply. And when I pay $500 for a piece of equipment I try to go by the book. So read your manual.smkettner wrote:
โJul-30-2016 09:49 AM
LScamper wrote:
pianotuna wrote:
"For some controllers running without the battery connected may let out the magic blue smoke."
