โApr-14-2014 07:48 PM
โApr-16-2014 08:16 PM
โApr-15-2014 08:27 AM
doughere wrote:
If the slot in the filler tube is mostly exposed ("a little past the bottom of the filler tube"), do nothing; over time it will go down. Watch during charge and if the level starts to cover the slot completely, you'll have to remove a small amount of electrolyte to expose some of the slot to allow the gasses to escape.
Doug
โApr-15-2014 07:33 AM
โApr-15-2014 07:06 AM
โApr-14-2014 10:30 PM
Old-Biscuit wrote:
Real good chance of water boiling out and all over top of battery.
Water expands when heated.....batteries get hot when charging.
Use an eye dropper, baster, straw with finger over top etc. to lower water level.
Should be 1/8" below vent tube IF battery has been fully charged.
IF going to charge battery..water level should just cover any exposed plates and then properly topped off after fully charged
โApr-14-2014 08:59 PM
โApr-14-2014 08:01 PM
