camilllit
Jun 28, 2018Explorer
Battery Float Charger(s)
I just bought a 2019 Cedar Creek fifth wheel. It has 2 batteries (12 volts each). There are 2 batteries because there is an inverter that changes 12vdc to 120vac for the refrigerator. My question is: When the battery disconnect switch is turned OFF, does that TOTALLY disconnect batteries from EVERYTHING? The float charger should not be connected if ANYTHING is connected to batteries. Also, I suspect I should use 2 float charges so if one battery needs additional charging it won't overcharge the other battery.
I may have answered my own question: Just disconnect both batteries and connect 2 float charges.......then it doesn't matter if disconnect switch disconnects everything.
Any thoughts, what do you all do?
