frecku's avatar
frecku
Battery life
I have a Class C rig with 6 X U2200 6V interstate batteries, they are about 5 years old, well taken care of, toped off regularly.
This spring cleaned the corrosion off the terminals and did a regular charge. Normally right after charging it shows a voltage of 13.5V and about a week later with the power disconnected a voltage of 12.8V, stable.
Never had any issues with them, I happened to have a battery hydrometer handy and tested all the cells. To my surprise all cells showed a voltage in the "white" between 12.25 - 12.50V.
Is that normal ? I do not think the hydrometer is temperature compensated. Do I still have life left in the batteries, they work just fine ?
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
