RDMueller's avatar
RDMueller
Battery SG 1.295? Is that even possible???
...or have I just bought another useless hydrometer that should be tossed along with the one with the 4 floating balls and the EZ-Red?
It is a Hydro Volt and after reading about it, I thought it just might be the "better mouse trap." It is very easy to use and very easy to read, but if it's not accurate down to at least .002 or so, then I don't see the point.
All 6 cells of my two fully charged T105s read 1.295 +/- .001 even though 1.277 should be 100%. I've gone thru this before with other things, my DMM for example. I had one that I've used for years that I started to become suspicious of because it disagreed with the voltage display on my Powermax and the ammeter/voltmeter I had connected to it. Bought a new DMM and what do you know, a 0.3V difference!
I'll just say this, I HATE instruments that are not properly calibrated! Just so frustrating :M
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
