MEXICOWANDERER
Mar 10, 2016Explorer
"Muh clock sez itz 3709 Ayem. Gonna put the clock away 'till the sun don't rise. That'll fixxem"
'Bout four years ago I predicted Herb Tarlek had nowhere left to run except increase acid density and shorten warraties. Both have come to pass. Are you surprised?
A hydrometer is a tool. It is useless unless it is accurate and in the hands of an educated adult. No flooded battery uses 1.400 density electrolyte. Or is this going to turn into an Abbot & Costello routine? No you cannot suck acid out of an absorbed glass mat.
The hydrometer is garbage. Get over it. Half of you have metering and instruments that would make an osciloscope gag. If a person utlizes a hydrometer to do meaningful things get a real one.
