jsummers72's avatar
jsummers72
Battery tender & storage
I have to store my rv in AZ for 4 months. I won’t be able to check on it, cause I live in AK. I’m wondering about leaving a Battery Tender attached for that long. I have covered storage. I have a battery cutoff in a new Arctic Fox tt. After checking water level- Should I … leave cables/wires attached to battery as they are; turn the cutoff switch ( disconnecting it from the rV) and then attach the Battery Tender? Everything I read say check water level monthly, but I can’t do that. Advise pls. Thnx in advance.
