gbkim
Oct 28, 2017Explorer
Hi John,
I know it's been awhile since you fixed you frame.
I had a question about the steel used for the sister plates, gussets.
Do you buy the same 70ksi rated steel to match up with the frame's steel as well as the 7018C welding rod?
I often read where a steel reinforcement is welded on, but no mention about the type of steel.
Any pictures of your repair?
Thanks
Gene
Thanks
Gene
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 23, 2025
