Berg extended run fuel tank question
johndeerefarmer
I am looking at the Berg extended run fuel tank for my Honda genny's.
Two questions.
One: can I only use it with one at a time? I mean how do you block the line that you aren't using at the time?
Second, what about the metal caps? Anybody stripped their plastic threads off of the genny's fuel tank?
I would prefer plastic caps but don't have the time to find the parts and build my own system.
2020 Ford 350 6.7 PSD & 2017 F150 3.5 EB max tow
GD Reflection 29rs
6 REPLIES 6
mlts22
I've seen people add quick disconnects that when disconnected, shut off fuel to that line. Fuel petcocks also work to be 100% sure that the line isn't in use.
johndeerefarmer
Thanks
GD Reflection 29rs
Devocamper
If you buy the dual run tank it should come with a small valve in the line to each cap you can shut of one or run both, my tank from wise sales came with black plastic valves , one shuts off the main line from the tank then one valve for each cap also bought an extra set of caps for travel.
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
Have not done this but I assume you can make a plug up??? Remove one of the lines at the "T" and put the plug on.... take a inch or two of hose , seal off the one end and place the other on the "T" . . .
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
johndeerefarmer
That is who I am looking at. I want dual run but only want to use one genny with it part of the time. The question is what do I do with the other hose when only using one genny? Can it be removed and capped off?
GD Reflection 29rs
check out Wise Sales... you can get single run... or dual run... I have not run mine with the aluminum caps yet , but do not see an issue...
Me-Her-the kids
