Birth Of The Gigawatt
MEXICOWANDERER
Jim in Denver's Megawatt has been perverted. Larger toroid choke, 80 amp 150 volt diodes rather than 30 amp 100 volt. Panasonic 680uf caps, 10x more airflow via two external roof fans. And...
57.2 amperes* into 12.0 volts for 9 hours and 10 more or less minutes. 16.67 wide open volts. Didn't even breathe hard. Cool to touch on rectifiers and bi-polar transistors. Like having a Derringer 12-gauge.
I did delta the three positive and three negative circuit board terminal strip output screws. Total fans drive current .84 amps. Transistor life will be a "maybe".
*three instruments verification
Tinker Tinker Tinker ...
30 REPLIES 30
happycamper002
MEXICOWANDERER wrote:
The secret of more amperage is...choke...choke...it is politically incorrect straight D.C. but it has multiple body piercing (fans) but no tatts. It would never make the cover of Time or People magazine like A Buff and Beyonce.
Sounds an impressive project to take on.
Toroidal Transformer does have qualities that is better than regular generic rectangular shaped core.
Not only that it is more efficient on a given size, it possesses better magnetic leak shielding, thus, minimizing hum in sensitive audio/video equipment.
Yes, EMF shows lines on my TV. . . and with all these complexities of new electronics, these lines even show up on my forehead and even more increasing as days go by.
One blaring disadvantage over conventional (rectangular core) transformer is cost. Hence, toroidal converters cost more than conventional model. Frankly, I don't think they make this rectangular core for RV any more. They are too heavy.
Since the coil has to be wound around doughnut shaped laminates, production is slow compared to rectangular laminates.
You did mention gigawatt. What exactly is the projected output in watts?
Interesting project indeed. . . care to share the result?
Gene_Ginny
DutchmenSport wrote:
What in the world is this topic discussing?
... bi-polar transistors. ....
Canadian Rainbirds wrote:
..Mex, the bi polar transistors would be more stable on a lithium regimen.
Mental health week. :h
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Nick-B
Nick
1995 Coachmen Santara MB360 w/slide
F53/460 chassis w/tag
Canadian_Rainbi
Lwiddis
AND IM RETORTING PRODANT139 TOO FOR ONLY SAIDING SAFE THINGS.
BrianinMichigan
Is it a variable output and is it regulated?
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
Corkey05
Laughs ... it's a "Mex topic", you just keep reading till you find enough words you know to make a sentence, then hope it makes sense. :h :B
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
profdant139
Well done, Mex! (I have no idea for what, but I figured it was a safe thing to say.) 😉
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
horton333
Well it sounds powerful, whatever it is.
Ford Explorer or Chrysler 300C to tow with.
Tracer Air 238 to be towed.
Triumph Thunderbird Sport - with the toy-hauler gone it's at home.
Retired very early and loving it.
Ed_Gee
Lwiddis wrote:
IM RETORTING YOU ALL TO THE POWERS THAT ARE.
Me too. I think it is about " Jim in Denver's Megawatt " .......whatever that is......
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
horton333
Thanks, I was worried it was just me. 😉
DutchmenSport
Lwiddis
TakingThe5th
It's unfortunate that there is so much choking going on in DC, lots of resistance too. It with a song in our hearts and nails in our tongues we fordge ahud.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
MEXICOWANDERER
