Birth Of The Gigawatt
MEXICOWANDERER
Jim in Denver's Megawatt has been perverted. Larger toroid choke, 80 amp 150 volt diodes rather than 30 amp 100 volt. Panasonic 680uf caps, 10x more airflow via two external roof fans. And...
57.2 amperes* into 12.0 volts for 9 hours and 10 more or less minutes. 16.67 wide open volts. Didn't even breathe hard. Cool to touch on rectifiers and bi-polar transistors. Like having a Derringer 12-gauge.
I did delta the three positive and three negative circuit board terminal strip output screws. Total fans drive current .84 amps. Transistor life will be a "maybe".
*three instruments verification
Tinker Tinker Tinker ...
30 REPLIES 30
NinerBikes
landyacht318 wrote:
Pretty sure JID's megawatt is the same one you use. It died when conditioning some large 8d lifelines IIRC
He mailed the failed unit to Mex who found the failed transistors, and upgraded them and capacitors, and went all mad scientist on it, and now it can do 56 amps.
Which is dang impressive considering the tiny size of a Megawatt, even with two larger fans on top of it.
That's why it has Giga cooler fans, it needs it when pushing the electronic guts that hard.
Gene_Ginny
happycamper002 wrote:
...To be met with insults and hostility "too much Mezcal, what are we discussing, bipolar mental health etc." don't contribute to the understanding that is needed to grasp what the message is.....
I don't think there was any intended insults or hostility. I think Mex understood it as having some good natured fun by those that have read his posts over the years.
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Gene_Ginny
MEXICOWANDERER wrote:
... The posts are not created for basket weaving 101 attention.
That is why we sometimes like to have a little fun with them. :B
Gene and DW Ginny
MEXICOWANDERER
PS The lithium joke IMHO clever and funny. But overly critical folk always seem to provide a dearth of useful imformation. Strong opinion perhaps but always lacking in information useful to others. There exists a time and place for fun learning. I try my best to avoid causing near comatose reaction. My obtuse manner is deliberate. The posts are not created for basket weaving 101 attention.
MEXICOWANDERER
Teaching groups of cruisers I found dry aeserbic monologues brought forth thumps caused by boredom that mimicked narcolepsy. Teaching does not imply learning. Some folks can recite RBAs from Wprld Series two decades ago then yowl if they should have to memorize basic electricity. Go Figure.
happycamper002
Lwiddis wrote:
IM RETORTING YOU ALL TO THE POWERS THAT ARE.
Mex's post is typical as his other posts we've seen in other threads.
We are all familiar with the tangents, metaphor and hyperbole. . . but there really is nothing wrong with them. Mex's post may seem cryptic demonstrated by other responders but the importance of what is being said is what matters.
Perhaps (whether) other members are just clueless is what brought this upfront. . . nobody will ever know.
Whether it is milliwatt, megawatt or gigawatt is not important.
There is an idea out there that we can all benefit from. . . and that is what this thing is all about.
We just need to think "outside the box".
Now, that's another metaphor.
All the best.
landyacht318
NinerBikes
landyacht318 wrote:
This is the gigawatt, not the borg! Get your chargers straight man
Correct me then LY.... what is the basis PSU for this and how many bones did it cost, I admit, I have not followed Jim in Denvers thread on this unit.
mike-s
Too much Mezcal will do that.
landyacht318
NinerBikes
760 watts sustained 9+ hours. It smacked its lips. Don't ask about the parts cost. $15 / 5 rectifier purchase. $9.90 2 caps. $12 fans and grills. About $3 for the Sil Pad./
You forgot the cost of the 2 Megawatts. Are they the 30 amp or 36 amp versions of switched power supply units, like Ham Radio operators are wont to use?
Probably good for recharging some Ampere hungry AGM type of cells that have very, very low internal resistance.
MEXICOWANDERER
JiminDenver
Gee Mex, sounds like the Lifelines might not chew it up and spit it out quite as easy as they did the first time. I have a 30 amp version from the other company but haven't even thought of wiring it up since the 435w portable has the heavy lifting done by the time the roof system even has a chance to get going.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
pnichols
This subject reminds me of where our stick and brick electric bill is going if we don't install solar soon. :B
2005 E450 Itasca 24V Class C
