Acampingwewillgo wrote:
I also drove over today to begin my adventure into Solar....but
here's a quick question....the price on a 230 watt 24 volt panel was/is 135.00, the 120 watt 12v panel was/is 115.00 sooooo on my roof I don't really have room for the larger 24 volt panels but if one could combine a single 230 watt 24v panel with additional 12v panels run in series. is that workable? To make my question easier, I have one spot on my roof where I could fit a larger panel, as in 1.....I could probably put up to 6 additional 12v panels(3 sets run in series) and then all together. Any feed back on that configuration and if doable, what charge controller would one use.
If not this year maybe next year when I've figured all this out.
Lots of options. They all work, so it is just a matter of cost and convenience, etc.
You can have the 24v panel and its MPPT controller as well as the 12v panels and their PWM controller. Put the two controllers set to the same voltage on the battery bank and they will add their amps.
If you put the 12s in series among themselves and then put that in parallel with the 24, the MPPT controller would get confused unless the two sets happened to have the same Vmp, so that is why to have two controllers.
You could put the 12s in series with an MPPT controller and use two of those but it costs more and you don't get much gain over PWM with 12s in parallel, which is why one MPPT and one PWM since the PWM costs much less than the MPPT.
You can have all sorts of combinations that might be the least cost depending on sales at the time, but it will take more wiring. Wiring is fairly trivial in the big picture if you are doing this yourself.
You have to be comfortable with being a little unconventional to do some mix and match combos if you want to get the most solar your roof can take in the various clear spots it has.
