Bill_Satellite
Aug 02, 2017Explorer II
Pick up one of these.
http://www.campingworld.com/shopping/item/rv-hydro-flush-45-degree/14496
It will allow you to connect a hose to that connection that will shot water backward up into the tank. If the valve is stuck closed the water will not be able to go anywhere. If there is a blockage of some kind this will push it out of the way. You will need to have the truck there or cap the outlet as if this clears the blockage you will experience an undesired experience very similar the the movie "RV".
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
