lifeinthesnaill
Apr 10, 2016Explorer
Both inverters died and now the one's fan runs constantly
I have been operating with a bad deep cycle battery since I bough the motorhome last August. It really wasn't a big deal. I could charge electronics with two 400 watt Cobra inverters while driving. Lights and water pump always worked fine. Rarely plugged in at rv campgrounds. I installed a 100 watt solar panel and solar controller a month ago. Now, even when not driving I could charge electronics as long as the sun was out. The other day I decided it would be nice to be able to actually store power in my battery, so I bought one at Walmart. The Everstart 24dc. Before installing the new battery, I never had any problems charging my laptop, cellphone and camera battery at the same time. The other day, I was only charging my laptop. When I went to unplug it, the inverter started burning up. I could smell it. I opened it up and the two fuses were burned on their negative sides. The other inverter had just randomly stopped working a couple of days before. No signs of it burning. So I bought a new inverter at Walmart 410 watts made by Schumacher. When I charge only my laptop with the new inverter, the fan runs constantly. What is the deal? I have plenty of power. The solar controller indicates the battery is charged and healthy. Any ideas why my inverters went bad and now this one's fan won't stop running? If I just charge my phone, it the fan doesn't run. It's with the laptop charging that the fan turns on immediately. When the old inverter burned, could it have scorched the wires causing them to work less efficiently?
