Brake problems
wvbike_99
Installed 2 new axles in my RV this winter, hooked up truck (2010 F150) with factory brake controller and it says all is ok, pull camper and applied manual brake lever and very light brake applied even when maxing out the controller to 10. So jacked up wheel and lever will stop wheel but when brake petal is applied nothing, moved to next axle and same result? Tried with engine running and also in gear still nothing,any ideas? Going to have my son hook up his truck to see if its on my truck end. All wires are hooked up and brake lever will activate brakes on both axles???? Help
2012 Primetime Tracer 2640 RLS
2010 Ford F Super Cab
5.4 Engine, 3.56 Gear
Factory Tow Package
Equilizer Hitch
Wife and Myself
No Cats or Dogs
13 REPLIES 13
westend
Lynnmor wrote:
westend wrote:
BTW, the Ford brake controller is an inertial controller, i.e. truck needs to be moving for the brake pedal to send power to the umbilical.
No the Ford controller is not a stupid inertial controller, it senses brake fluid pressure so that the trailer brakes does what you foot wants them to do. Ford did program the controller so that it provides very little braking at very slow speeds to prevent jerking. The trailer brakes need to be tested while driving.
I stand corrected, thanks.
'03 F-250 4x4 CC
Gdetrailer
stickdog wrote:
For proper adjustment and operation of Ford brake controller READ YOUR OWNERS MANUAL.
:R
Really??
Ford controller is brain dead stupid to "setup"..
Hook up trailer, set the controller output with the up/down control until you feel the trailer brakes slow you down at low speed (25 MPH or a bit lower) when using the manual lever..
After that you simply drive normally and if you want more or less braking you can up or down the output to your liking when braking with your vehicles brakes..
You do not want or need the wheels to lockup when setting the output..
Much simpler than a P2 or P3..
Gdetrailer
Lynnmor has it correct.
For whatever reason folks seem to insist that Ford is using a "inertia" controller.. They are not.. In fact that would superbly STUPID for any vehicle manufacturer to use an inertia controller when they have EVERY POSSIBLE input available (MC pressure sender plus CANBUS data) to use built into the vehicle..
The Ford controller does however offer a REDUCED output when stopped which is to help hold the trailer load while stopped when on hills.. This lower output may not be enough to test your brakes when trailer tire are jacked up..
For testing your brakes you can simply pull the breakaway switch lanyard (make sure you have the trailer to vehicle cord disconnected ), this should LOCK the wheel as soon as you try to turn it..
Put lanyard pin back in and the brakes should let go and tire should be easy to spin by hand.
stickdog
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
Lynnmor
wvbike_99
Now if it is a Prodigy,
I had a Prodigy on my last truck so I thought they would stop the wheel when I had it jacked up, I have adjusted the brakes tighter and am hoping when they get a few more stops on them they will be ok, Thanks for the help from all of you.
Factory Tow Package
Equilizer Hitch
Wife and Myself
No Cats or Dogs
ScottG
When I operate my brakes going backwards, they grab HARD even with the lightest brake input. I think you will know it if they're that way.
Terryallan
not supposed to. IF the brake controller is an inertia based controller. The TV, and TT have to be moving for the brakes to be applied thru the brake pedal. Now if it is a Prodigy, and you have the boost set to 3. The brakes will apply for a instant, until the BC figures out the TV is not moving, then it will release.
The lever of course over rides, and sends power to the brakes. But the TV pedal won't. An inertia controller senses how fast the TV is decelerating, and sends the correct amount of power to the TT brakes to mirror the TV deceleration. No TV deceleration, No power is sent. No brakes needed.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
wvbike_99
I just adjusted up brakes and I called Dexter who said they need to break in but u have me wondering about axles being backwards, I installed with the tags facing back like my old ones, have to check into that, also Dexter said Truck has to be moving before brakes will work but the lever brake will work anytime? I didn't know that. Is there a way to tell about the axles without taking off the hubs?
Thanks for the reply.
Factory Tow Package
Equilizer Hitch
Wife and Myself
No Cats or Dogs
Roger10378
You say new install so the first things that come to mind are, brakes not broken in, not adjusted correctly, axles installed backward. Trailer brakes do very little if they are rotating backward. Brakes have to be seated in for a few miles with a number of stops and readjusted to do much.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
ScottG
If manually applying the brakes via the lever on the the controller makes them work satisfactory, then that suggests the controller itself isn't working right in its normal mode.
westend
You can check the brakes by using the emergency brake switch instead of the truck umbilical.
Don't leave the pin out for any long length of time but if you carry a compass around to the axles, and if the magnets are powered, it should swing the compass needle. If you have the wheels off the ground, you can also turn a wheel to check shoe->drum contact.
As was mentioned, adjustment is key to good brake operation.
'03 F-250 4x4 CC
Darryl_Rita
Adjust the brake shoes.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
