Building my DIY shower/bathroom, did I forget anything?
evy
Hi everyone,
I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250.
Right now I'm working on my shower/bathroom.
Before you ask I have a 5 gallon porta potti, so no plumbing and no black tank.
My shower base/floor will be covered with fiberglass (another thing I never done before but I think I'll be ok)
The outside insulated wall will be covered with 3/8" thick plywood and I will glue some plastic sheeting with plastic corners and tons of silicone.
The top wall will curve to meet the ceiling, I will use flexible loan plywood.
As you can see the Fantastic vent is inches away so I will only install a transfer grill on the shower wall.
I will be adding a small storage cabinet on the van's gas inlet bump (same height as the porta potti) and I will install a marine hatch on the side (I will remove the bag) and use it for toilet paper storage and porta potti chemicals. Initially I planed on putting a small corner sink with faucet on the cabinet but the kitchen sink is literally 2 feet away so...
This is the lighting fixture I bought, 46LEDs 5"diam, I will be adding clear silicone to make it waterproof.
These are the accessories I plan on using.
Toilet paper cover with soap tray
Shampoo dispenser
Extendable pole for hanging wet close/bathing suits/towels etc...
I also plan on installing a shower curtain that you close when taking a shower, to prevent water from getting through the gaps around the door.
That's about it, am I forgetting anything? do you have any comments or useful advice? Thanks!
_______________________________________________
DIY conversion build, extended 2010 Ford 5.4L E250 + high top, from Montreal Canada, new to all this so please be patient and clear with me (never built or camped in a van yet)
19 REPLIES 19
BoonHauler
Looking good to me, the only problem I see is where the walls meet the pan. As long as that interface is designed to allow for a little movement should be good to go.
05 RAM 3500 CTD 4x4 Q/C Laramie DRW/NV5600/3.73, B&W Gooseneck, MaxBrake, PacBrake PRXB, Brite Box Fogster, BD steering Box Brace
2014 BoonHauler 3614
Houston_Remodel
This guy seems to have it worked out http://flextile.com/
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
evy
I'm not an expert but I doubt the fiberglass will crack.
The base is made of 2"x2" 2"x3" and 2"x4" drowned in carpenter's glue with 3" screws.
mkirsch
Nomad II
Nomad II
Take a look at a plastic basement laundry sink with the legs trimmed off as a ready-made shower base.
It gives you a 24x24 mini tub to stand in, plenty big enough for a shower. It's flexible plastic so it can take some abuse where fiberglass will just crack. A distinct advantage is it's deep to contain the water better than a shallow shower pan. Plus it has a lip that you can install the plastic paneling over, so no excessive gobbing of silicone.
MEXICOWANDERER
Tips I learned from building Quicksilver
Floor has definite camber to allow fast draining. I used Teak slats and the ship's carpenter made a removable two-piece floor rack. Absolutely slip proof. And the slats are level.
Also with teak a flop-down seat is worth it's weight in gold. The shower wall needs heavy reinforcement to support the load. I used 1" square tubing.
I hang towels from the ceiling and a spring clip. Washcloth too.
I use my (portable) Fantastic Endless breeze fan to help dry the bathroom.
Houston_Remodel
If you do the entire shower in one continuous layer of fiberglass it will not leak, but then again it will not flex either. It may, or may not, break then leak when it does flex. To avoid this problem, overlapping joints are the answer as noted above.
Main areas of concern; where the walls meet, where the pan meets the drain flange, where the walls meet the pan.
The grey vinyl liner as shown provides no wall waterproofing which you will need.
evy
So what about this option.
I will add a piece of wood cut at an angle and I will use it to pin the shower base to the floor, and I will run the plastic sheeting over it without gluing it.
And If anything happens I can easily mechanically remove the shower base.
BoonHauler
is it friday yet? wrote:
The wall needs to come over the shower base, then you shouldn't need silicone. Build the wall out further or make the shower pan smaller on the vertical.
I would tend to agree with Friday. That detail looks like a leaker to me.
Just my two cents
is_it_friday_ye
2007 Dodge Ram 3500 Cummins SRW, Airlift airbags, Bilstein shocks, Smarty Jr., stainless turbo back exhaust, B&W Patriot 18K
2015 Grand Design Momentum 328M, disc brakes, Progressive Industries 50 amp EMS
evy
DrewE wrote:
Commonly in shower enclosures in RVs (and probably in other applications) the wall panels extend down over and in front of the lip of the base a few inches, with no sealant between the two. That allows for some movement of them relative to each other. Caulked joints don't last well when there's much movement at all (at least with traditional caulking materials like silicone), and any slight twisting of the vehicle chassis will cause movement between the base and the walls. There's probably less slop in a van chassis than a typical class C or A motorhome chassis, but I suspect still more than in a house.
There's no real need to put plastic on the ceiling IMHO. It's not harmful, just unnecessary. If water is dripping onto your ceiling, you have bigger issues than a wet ceiling.
Be aware that once silicone is cured essentially nothing will stick to it. This includes more silicone. Resealing a silicone joint requires removing every bit of existing silicone and thoroughly cleaning the area and is a major pain. Other sealants may be more suitable; I've generally had good success with OSI Quad, though I have not tried it in any bathroom or other interior applications.
Depending on your height and the interior space, you may want to consider a ceiling-mounted track for the curtain rather than a rod for greater headroom when entering and exiting the bathroom. Having the exhaust fan not be in the shower compartment itself is actually not a bad thing, in my opinion, as turning on such a fan in a tight shower stall tends to cause the curtain to blow in and stick to one's body. Having it tend to waft outwards is pleasanter.
I assume you've probably thought of this, but just in case you have not: put in a towel bar somewhere. I like to believe that a towel is less likely to slip off of a square one (such as I've installed in my motorhome) than a round one, but I'm not sure that it actually makes any difference.
Edit: if you leave the shower compartment door open while showering (and use just the curtain to keep water where it belongs), the inside of the bathroom compartment door would be a decent place to hang a towel. If you have it some other place in the van to dry, you could just toss it on your kitchen counter or something before stepping in the shower and reach it when you need to dry off.
Here's a quick drawing of how I planned on doing this, So you're saying that the flexing of the vehicle when in movement will crack the joints and they won't be waterproof anymore? Also I'm not using the right material (silicone)?
is_it_friday_ye
It is, but it's thick and I thought maybe you could put some kind of floor over it. What about some tiles that water flows through, like those 12x12 garage tiles? Just an idea.
evy
Use this on your shower floor. I used this product in my house addition for the shower and it hasn't leaked at all. This is an image I found on Google. They sell it at Home Depot, Lowes, etc...
Isn't that a shower membrane they use when they make a ceramic shower?
is_it_friday_ye
DrewE
