Bulk trailer wire
mkirsch
Nomad II
Nomad II
I want to run 10ga wire to the brakes on one of my trailers.
The only place I can find any sort of vehicle wire locally is at the auto parts stores, and white 10ga only comes in 10' rolls. That isn't even enough to get from the tongue to the front axle, so I'll have splices all over the place.
The stuff they sell in larger rolls at the big box home improvement stores (THNN?) is real stiff with thin insulation, tough to work with and probably won't hold up to the vibration from the road.
So where's a good place to get this stuff from?
10 REPLIES 10
ScottG
I bought a 25' roll of light blue #10 wire at ACE hardware.
time2roll
westend wrote:
Marine grade wire available at Genuinedealz.com
I give five star rating right here.
wa8yxm
Radio Shack has it in long rolls. So does Home Depot, Lowes, Most hardware stores.. You may even have your choice of Stranded (Radio Shack) or Solid (most hardware/Home Improvement places) Many may have both (not Radio Shack)
I also have a host of sites I can send you to. Let me check a favorite.
Alas they had only smaller sizes. But I did find it at Radio Shack, red or black, 20 bucks for 35 Feet. Stranded too (What you need).
RoyB
definitely go with marine grade wiring... Made for trailers and boats and will survive undertrailer road spray...
You should be able to find what you need from AMAZON in any lengths you need...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Nicholsfamily05
I ordered a 50' roll from Amazon last summer when I rewired our ATV trailer. Good price and shipped two day
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
enblethen
Many marine supply will have what they call duplex wire. Good for brake cable.
West Marine
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
j-d
Seems like a couple OP's have your wire sourced, so I'll just add that Marine wire has the copper strands protected by Tinning, useful in that exposed are of your RV chassis.
And, let me mention something a good RV parts & repair shop (Karen's in Anchorage) told me: Don't use the axles as conduit for the wire. They rust inside and the rust abrades the insulation. Better to band the wire TO the outside of the axles. From my experience on boat trailers, Black Plastic Electrical Tape holds up longer than ZIP Ties.
Marine wire has the copper strands protected by Tinning, useful in that exposed are of your RV chassis...
My family used Karen's. I have used Mobile Trailer (also in ANC) and been very pleased with them. Both are on the North end of town, near the rail yards.
RJsfishin
This little Napa here in this little town sells all wire off the big rolls.
I would think all the Napas do.
Rich
westend
'03 F-250 4x4 CC
agesilaus
Amazon: link
I see 25 ft rolls and 100 ft rolls
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
