wopachop's avatar
wopachop
Can AUTO mode damage A/C from frequent shutdowns?
Have a dometic air conditioner with the wall mounted controller. The A/C reacts differently based on the FAN setting being low, high, or auto.
If the fan is set to low the A/C runs 24/7 on the low fan speed and i can hear when the compressor kicks off and on.
If the fan is set to auto the A/C will bounce around between running on high, low, or completely shutting off.
I have heard A/C guys say you need to let it rest for several minutes after a shutdown. It seems like my RV rooftop A/C can turn off and on within a minute. It also sounds like a long pause of nothing when it switches between high and low fan.
To battle this i set the controller temp super low so the A/C stays running. But i would prefer if i could set it to 85F when im gone. Not sure which of the fan settings would do the least amount of wear and tear on the ac unit.
