TurnThePage's avatar
TurnThePage
Can I add a bit of hose between drain and macerator?
Instead of hanging the macerator off the black/gray drain, can I add a couple feet of hose between them, allowing the macerator to set on the ground? Any reason not to?
  • I like having a clear elbow before so you and see when it's almost drained.
  • Bobbo's avatar
    Bobbo
    I think it is. Now, if you were driving down the road with it hanging on there, I would give a different answer. Driving down the road, when you hit speed bumps or potholes, you have a dynamic load that is many times higher than just the weight of the macerator hanging on there while it is sitting still.
  • Is it silly to worry about the weight of the macerator hanging off the drain?
  • My only concern would be getting that regular sewer hose fully drained, plus an extra item to clean.
    But mechanically using it that way, no problem.
  • wa8yxm's avatar
    wa8yxm
    Done it up to around 30 feet on one occasion. (Had to use a portable battery for the pump).
    At least one model comes with a short length of 3" hose on the inlet (This model is mounted in the RV.. gives you the choice of using the pump or a straight 3" stinky slinky).
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
