XR4rider
Feb 17, 2016Explorer
Can I get help with battery math...batteries-inverter-coffee
I was wondering if someone can help me do the math for running a Keurig mini single cup coffee maker off batteries. The Keurig says its 1400W. The machine, when plugged in, takes about 3 minutes to make a cup of coffee. I have a 2000W inverter to 2 6-volt batteries (225Ah). I also have a 100W solar panel on the batteries as well. I've been reading some watt-amp-amp hour formulas but get a bit confused. I am wondering if making a cup of coffee in the morning will be harmful to the batteries. During the day we do not use any power so the panels help re-charge the batteries, plus I do have generators that I can run to help re-charge. I feel I have enough time in the day to put a good re-charge to the batteries...but my concern was using the Keurig will deplete the batteries to a point where they wont re-charge or hold a charge. Thanks for the input.
