Can I Modify Portable Gen Exhaust ?
stevekk
Has anybody modified the way the exhaust was pointed on your portable generator.
Like rather than exhaust shooting straight out of the back,
installed a 90 degrees elbow?
A master small engine mechanic told me not to modify the exhaust since it would change the back pressure?
I have a Yamaha 2800 and would like to mount it on/ near the rear bumper.
But the exhaust would be headed straight into the back of the RV.
Any ideas? THANKS..
5 REPLIES 5
MrWizard
Moderator
Moderator
you would on an old B&S engine with a 3 inch exhaust/muffler
newer designs with large mufflers have bolts/supports hoding the muffler/exhaust
any weight there might affect the 'exhaust Tip' but not the engine manifold
a number of people have modified the exhaust of the cpe 3000 generator,
with good results and no harm to the manifold
me i would use a piece of flexible exhaust wraped with heat tape and point that where wanted
MEXICOWANDERER wrote:
Careful with any extra added weight! It can fracture the aluminum cylinder head threads like plastic. You would absolutely have to design and install some kind of a bridge hanger to support the pipe bitter end.
I can explain it to you.
1997 F53 Bounder 36s
SaltiDawg
Any ideas? THANKS..
Steve,
Modifying Generators
VERY long thread, but maybe search "exhaust" or "enclosure" - when building an enclosure for noise reduction, inevitably the exhaust requires modification.
sljkansas
Could you add a longer platform, like a receiver hitch carrier and turn the generator around or sideways?
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter Married.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
MEXICOWANDERER
copeland343
My dad had same problem. The easy fix was to turn generator around on the rear rack. Even if you add a 90 you will/might still have the heat hitting your rear wall.
