kellertx5er
May 19, 2015Explorer
enblethen wrote:
Yes, there is issues with moving it. The GFCI receptacle must be the first in the circuit.
One way is to install a GFCI breaker in the 120 volt distribution panel.
Not correct. The NEC does not require an entire circuit to be protected unless it is the only branch circuit. When more than one circuit exists, GFCI protection is only required in certain areas such as bathrooms, kitchen, exterior, etc. A receptacle in a TV cabinet does not have to be protected. Moving the GFCI to the next recptacle downstream is acceptable as wnjj suggests.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
