Bobbo
Jun 11, 2017Explorer II
ScottG wrote:
The check valve in the pump isn't working. You can add a separate one or take apart the pump, clean it and it will probably work again.
If the check valve in the pump isn't working, it won't work right when on the tank either. Every time the pump turns off, all of the pressure would back flow into the tank turning the pump back on.
