j-d
Jun 13, 2017Explorer II
I found a Pleasure Way owner to ask about this. Theirs has a separate "gravity fill" as shown in the diagram on Page 1.
Does yours? In other words, do you fill your fresh water tank by directing the discharge of a hose down a filler pipe? Or, from the hose you connect at a campsite?
If you are supposed to fill with a "gravity fill" and your campground water connection is overflowing the fresh water (FW) tank, then I'd suspect a check valve as noted above.
If you are supposed to fill via your campground connection, then I think you have a tank-filling valve in the wrong position. Our coach fills from the campground connection, and if I have the valve in "Fill" it overflows onto the ground when it's full.
