Carbon Monoxide/Propane detector Blinking Green
RobWNY
Hey everyone. I need some help. If my camper is plugged into shore power, My Carbon Monoxide/Propane detector has a solid Green light. If I unplug from Shore Power and I'm just using my battery, it blinks Green. If I use the battery disconnect but I'm still plugged in to shore power, the detector stays a solid Green. If I unplug from shore power and also use the battery disconnect, then the detector has no light at all. So if a solid Green means it's working fine and no light at all means there's no power to it, what does the blinking Green light mean when only using the battery for power to the camper?
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
10 REPLIES 10
Straylight
wa8yxm wrote:
An easy way to think of it
Green is GOOD
Red is not
This reminds me of what one of my wilderness medical instructors said about snakes:
Red on yellow, kill a fellow,
Red on black, don't pick up snakes.
wa8yxm
Green is GOOD
Red is not
DrewE
blownstang01 wrote:
RobWNY wrote:
I found the answer. It can take up to 10 minutes for the alarm to "Warm Up" before showing solid green on battery power. Everyone can disregard this thread.
Exactly! That's how my Safe-T-Alert works. Directions say it takes approximately 2 minutes before it will work and go to solid green. Interestingly I just had to replace it as I was getting a fault....alternating green-red and a beep every 30 seconds or so. The manual says to replace every 60 months and the man date on the back was April 2013, still can't figure out how it magically shows a fault almost exactly 60 mos later. LOL
That's actually pretty simple; the little embedded computer inside maintains a countdown timer of how long it's been powered on (in non-volatile memory of some sort) and switches to "end of life" mode after it's been five years. There are also non-digital components that would work as a long-term timer, but these days a little microcontroller chip is so inexpensive that I'd be rather surprised if they did something else (and they probably want one anyhow to operate the detector for things like automatic recalibration if needed, detecting and ignoring some spurious alarm conditions, etc.).
blownstang01
SidecarFlip
ReneeG wrote:
SidecarFlip wrote:
Remember too that all CO detectors have a set lifespan and need replaced after a period of time. Comes under RV maintenance. Just like a new Anode rod in the HWH.
Note: We bought our FW new in 2010 and we just had to replace the CO detector this spring. It continued to sound a bad battery signal after new batteries. Referred to the manual and yup - time to replace.
Lot of that (time period) has to do with the interval between manufacture of the unit and when it's installed and used. CO detectors like flooded cell batteries start their life when made and are 'getting older and closer to their end of lifespan' even before you buy the RV. It's because the rare metal part of the detector element has a finite life.
Last one I had in my sold camper lasted as long as I had the camper...15 years.
They are not cheap either.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
ReneeG
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
ReneeG
Glad you found your answer.
RobWNY
SidecarFlip
Most every CO detector I've seen (including mine) states on the front (in small print) what exactly the light sequence means.
ReneeG
That depends on your brand of CO detector and what its manual says.
