NinerBikes's avatar
NinerBikes
caulking around doors and windows.
What is the factory type of sealant type material that you squirt out of a caulking gun that Forest River uses around all their door jambs, windows frames, vents, etc, on VERTICAL external surfaces. Some of mine in the heat of summer is starting to crack, and I want to completely go over the whole TT top to bottom early this fall when it is a bit cooler, before this Godzilla sized El Nino Winter hits us in California... I want things all buttoned up and water proof /tight.
I know Dicor is used on the roof, have 2 tubes of it already.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
