westend
Sep 08, 2017Explorer
Order of disconnection: Power from solar panels to controller (if you have MC4 wire, you can unplug), negative phase connection from batteries to frame ground. Disconnecting batteries first may injure the solar controller.
FWIW, I installed a Hi-watt manual breaker between the solar panel and the controller. It makes it awful easy to disconnect power from the panels to the controller, when servicing the 12V system.
