cgmartine's avatar
cgmartine
Charging batteries as 6 or 12 volt
I just bought two Trojan T-105 batteries to replace my house batteries, but I will not be installing them until my next trip in several months. In the meantime, I will be placing the batteries on my garage floor. I have a slow trickle battery tender that I use on my motorcycle that I can use (1.5 amps) or a heavy duty battery charger.
Should I charge the batteries individually as 6 volts, or together as a single 12 volt?
Second question: Which ever charger I use, should I place the negative lead of the charger on the negative battery post that would go to the body frame (battery #1), and connect the positive lead of the charger to the positive post of the battery that is connected to the motorhome? The batteries (in series) will have a cable from the positive post of battery #2 to the negative post of battery #1.
I hope this makes sense!
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
