Charging the Lifelines questions
JiminDenver
As you all know, anything more than clipping the auto charger onto a battery is well above my pay grade, so I have some questions.
For the regular charge before the conditioning charge, the Lifeline manual calls for a voltage limit of 14.3v at 77 F for absorb. I am assuming that is the point I have the controller switch out of bulk. Correct?
Second thing is the Eco-W can handle doing that but can only handle one panel. That's not much of a C rate on a 8-D. Is it worth setting up that system to work on bringing one of the batteries up while the big system does another, or should I just work on them one at a time?
I'll start searching through the post for what stand alone charge I will have to get to plug in at home. I am not interested in a fancy converter since the trailer never gets plugged in to anything but the solar.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
103 REPLIES 103
reed_cundiff
Mexico Mike
Are you in Michoacan or Vizcaino Desert/Biosphere?
Reed and Elaine
pnichols
Mex wrote:
Presently I am at 111F inside the house and maybe its 121F or so outside. ... The locals are suffering. They aren't used to heat like this. The bad part is the humidity - 52% and it is clouding up. There's going to be some deaths in this pueblo over this and I feel sad for them. No one including me has home insulation.
Mex ... you need air conditioning ... pure and simple.
.... or next best - a rock wall with water running over it like the one in Scotty's Castle. Don't delay.
2005 E450 Itasca 24V Class C
reed_cundiff
Mexico Wanderer
Two questions:
1. Where are you that it is 46ยฐC?
2. Why are you staying there?
Time to go north or up in elevation. It was 105ยฐ F at son's place in Fort Collins a few years ago so went up to 10,400' just north of Rocky Mountain National Park and it was max of 75ยฐ F during the day and 38ยฐ F at night.
Reed and Elaine
MEXICOWANDERER
Reed, now -that- would work. Presently I am at 111F inside the house and maybe its 121F or so outside. The Lifeline is disconnected. The locals are suffering. They aren't used to heat like this. The bad part is the humidity - 52% and it is clouding up. There's going to be some deaths in this pueblo over this and I feel sad for them. No one including me has home insulation.
Extremes like this are totally outside the control realm of battery converters or tenders. At 120F charging, even maintenance should altogether cease. The acid is just too corrosive. In Las Penas I would be in the ocean. Here it is 68 degrees with horrendous undertow. Obviously the breath of air is onshore. Oops we just gained another degree. We have another hour to go before it peaks. Past 111F it gets uncomfortable for me. 124F is the record here in the Vizcaino Desert. Just threw water on my stainless tubing hand rail outside and it steamed off. But the tomatoes, bananas and papaya are digging these temps!
JiminDenver
I had a thread asking about AGM's and extreme temps before I bought the Lifelines. I wanted the info before I laid out the cash.
The fan on the MegaWatt is already making a horrid noise. Good thing I have some laying around.
reed_cundiff
I don't think the 45 C is hard and fast. Other blogs state 50 C (122 F) It doesn't mean much more than possible slight degradation. Chris Dunphy was probably up to 140 F in his battery compartment.
MEXICOWANDERER
Whatta bummer. It got to 46c here three days ago. When I fire up a generator using $3.80 gallon fuel to recharge a deeply depleted battery in warm temperartures the last thing I want to do is trickle charge a huge bank. I suspect that high temperature limit is for the core of the lithium battery and with the risk of overheating and fire, that worries me. Lithium is appropriate for some folks it seems but not for others. I seem to be on the "excluded" list. I would like to take this opportunity to thank you for clarifying this for me. I'll have to make do with flooded and AGM.
reed_cundiff
Mexico Wanderer
Standard LFP will discharge at fairly low temperatures. The minimum values given in literature for discharge at low temperature are between โ€“20ยฐC and -30ยฐC. The problem is in charging at high C charge rates and there the minimum temperature is 0ยฐC. It is quite likely that the low C charging rates of solar in the morning may mitigate this. We left our rig at son's place in mountains of northern NM for the last two years when we flew to Central America one winter and South America for another winter and it got down to โ€“30ยฐC. Inverter was off (it has a parasitic draw of about 100 W) and so the battery suite was never discharged more than -300 W (-3% of total charge) so that charge rates would have been extremely low.
It is possible to heat the battery storage area with heating pads and/or incandescent light bulbs (30 W or so). We have done this to keep the main luggage are (basement) warm on cold nights to prevent the pipes from freezing. This kept the baggage area to upper 30's on nights that got down to โ€“23ยฐC. We have sufficient battery storage to do this.
The other worry is high temperatures and the limits are 45ยฐC for charge and 60ยฐC for discharge. Cris Dunphy of Technomadia blog has written candidly with problems of possible overheating when they were parked on tarmac in Phoenix during the summer for several weeks. The LFP battery bank was in a non vented compartment with the inverter and the temperatures could have been fairly high. We leave the battery/inverter compartment (8' x 2' x 3' or so) open when using inverter to run air conditioner. We plan to eventually install a couple of 12 V receptacles for 12 V fans (12 W) for increased circulation.The same receptacles will work for incandescent lamps.
Have installed a remote thermometer in the battery (otherwise known as a $15 Walmart inside/outdoor thermometer) to monitor the temperatures in the bay. The highest we have measured was 32ยฐC when it was 34ยฐC ambient.
Reed and Elaine
JiminDenver
Here the temps range from 20 below to 100 or more above, I had to consider that in my choice.
NinerBikes
Maybe I'll buy some used Teleco Li FePO4's some day, down in San Diego...
MEXICOWANDERER
Gotta travel through cold country to get to warm country. I remember -5F in Kingman AZ. in Ennis, one winter it was -44F. Throw a glass of water up into the air and it came down ice crystals. The temp thing is a real negative for some folks. If the vehicle charging voltage is incorrect and needs a high power converter WOW! I'm confident they will iron out the problems - the batteries have too many good points to ignore resolving their shortcomings.
JiminDenver
I remember someone on one of the solar forums saying that it gets too cold here for Lipo, like I can afford those.
KJINTF
Posted By: MEXICOWANDERER on 08/10/15 04:36pm
KJINTF,
Out of curiosity how do your LiPo's perform in 10-degree winter Montana? This is a genuine question and not some goofy challenge. I've read some really suspicious comments about Lithium batteries and cold weather performance. Thank you for your response in advance.
K.J.
in Three Forks ?
Mex,
Sorry I have no idea how they might respond to such extreme temps since they never see anything near that cold. The rig is stored for winter non use period in my heated shop from October through April. 40F is as low as it gets in the shop when I am not there. Further west from the confluence of the Madison, Jefferson and Gallatin we rarely see anything below 0F for low temps anymore.
Further west - TF Thompson Falls the not so windy side of the mountains
NinerBikes
JiminDenver wrote:
Yahoo
The second conditioning charge brought the low battery up to 13.1v after a 24 hr rest. I redid the top charge on the other two and am waiting to see how they settle too.
My question is how much of a difference can there be? I may end up with three batteries with slightly different voltages, off by .01-.02v from each other since I am working on them separately.
I REALLY want to use the full bank and not have the hassle of separate banks. Two 8-D's would be acceptable had I not used all three and seen what they can do. No more waiting for the sun or needing the solar to boost the bank, just push the dang button and it will be ok.
A read in the Odyssey instructions clearly states that 3 full attempts at equalizing, with OCV being measured in between each attempt after 24 hours might very well be necessary to clean up and bring a battery up to full voltage. What it sounds like is you are doing a brute force electrolysis cycle event to suck all the sulfur off the plates and back into acidic solution, and that it takes rest time in between for solution to penetrate minute nooks and crannies, such that it can take more sulfur into battery acid solution. This is heavy duty elbow grease brute force cleaning of the residue left on the plate, due to incomplete recharge cycles. They recommend doing so every 10 partial recharge cycles.
The best means of avoiding this is to get your battery top charged almost every single day, completely topped up, pretty much like you do with a car battery if doing longer drives with the alternator.
The brute force is where a big amp capacity power supply unit controlled manually comes in, you need those big amps with an AGM battery. It explains why the alternator has such high capacity on my AGM battery for my VW Touareg TDI diesel, the battery takes it at that rate, and has to, to maintain battery longevity.
