Snowman9000's avatar
Snowman9000
Clamp ammeter specs
On an inexpensive clamp ammeter, the DC current spec tolerance is 3.0% +6.
What does the +6 mean?
  • Error is normally based on the range selected
    3% + - 6
    On a 100.0 range setting
    % = 97.0 to 103.0
    at one hundred amps reading, 100.0 on the dial
    plus minus six digits 97.0 minus 6 = 96.4
    to plus 103.6
    Now, do you see why I squawk about my 5 digit voltmeters? 1.5% error = - 3 digits.
    The cheapo Bang Good clamp on ammeter I have reads up to 40.00 on low scale and it is FAR more accurate than the hurricane destroyed Triplett that cost three times as much.
    One amp resolution is fine for me at 500 amperes.
  • So what is the error range for a reading of 1 amp? Depends on the decimal places after the 1?
  • DrewE's avatar
    DrewE
    2oldman wrote:
    Then shouldn't it be ±6?
    The +/- applies to both the 3% (of the reading) and the 6 counts. In other words, it's +/- (3% plus 6 counts); for readings that are well lower than full scale, the 6 counts could easily be a much greater error than the 3%.
  • ktmrfs's avatar
    ktmrfs
    no.
    OK, a good digital meter will have spec reading something like
    +/- X% of reading +/- Z counts
    E.G. +/- 2% +/- 6 counts
    usually AC accuracy is worse than DC accuracy,
    For AC accuracy a frequency range and crest factor range is usually specified. Crest Factor= Peak to RMS ratio. Crest factor for a pure sine wave is 1.414. The peak voltage is 1.414 times the RMS value. Square wave centered on 0V has a crest factor is 1.
  • wa8yxm's avatar
    wa8yxm
    To me it means it may round UP on 4
    IEL 20,4 anps might show as 21 amps.
  • Gotta remember these ads are formulated by folks who understand
    I have a cheap digital meter I purchased from BANG GOOD and it works great. The 40 amp DC scale measures amperage like 16.36 so the least significant digit is truthfully not significant
  • Range of tolerance with the last significant number having a tolerance spread up to 6.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
