โOct-02-2013 07:22 PM
โOct-12-2013 12:34 PM
โOct-11-2013 01:27 PM
MEXICOWANDERER wrote:
Fluke, Triplett, the usual suspects.
โOct-11-2013 11:47 AM
โOct-10-2013 07:43 PM
Inductive DC ammeters as Matt Collie pointed out are near useless at low scale. Worse than useless, they are misleading. Horribly so.
For low current measurement, use your DMM, on the 200ma scale if you want to stay out of the land of OZ.
For PRECISION measurement of low value amperage I use a MANGANIN 20 amp shunt and a 4.5 digit DMM (6.5 digit when I get real serious). This would be worthlessly precise for most RV applications.
Measuring very low values of amperage with an inductive meter would be similar to timing a 100-meter dash with a sundial.
โOct-05-2013 10:57 AM
โOct-05-2013 10:38 AM
otrfun wrote:
Just purchased a new Mastech MS2108 clamp-on meter which measures true RMS and inrush current (not to be confused with the cheaper, less capable MS2108A).
-- snip --
... the inrush current for the compressor start-up is another story. I measured 61 amps! It dropped to 58 amps with the generator in Economy mode.
-- snip --
For comparison purposes I also measured the current and inrush current on our microwave inside the house. It measured 13.2 amps with 48 amps of inrush current.
These inrush measurements seem very high. Is this possible, or do I have a very inaccurate meter? FWIW, followed the manufacturer's directions closely for measuring inrush current. They're very simple.
โOct-05-2013 08:34 AM
โOct-04-2013 06:35 PM
โOct-03-2013 08:41 PM
dclark1946 wrote:
I use both an Extech 40/400 A true rms clamp on and a Sears combined DC clamp on /multimeter. The Extech has a zero function and will resolve down to 10 mA and the lower cost Sears unit will not resolve down as low but it also has a zero function. These units are pretty accurate. You are smart to add this type of meter to assist in monitoring maintaining your 12V system.
Dick
โOct-03-2013 07:24 PM
โOct-03-2013 02:29 PM
โOct-03-2013 12:57 PM
mena661 wrote:Matt_Colie wrote:Aren't the clamp-ons hall effect? Are those inaccurate too? Also, how inaccurate are they? My meter has an accuracy rating, are those typically incorrect? Sorry for the questions this is the first I've heard of this.
AZ,
DC current probes are notoriously inaccurate.
โOct-03-2013 10:31 AM
AZ,
โOct-03-2013 09:05 AM
Matt_Colie wrote:
AZ,
DC current probes are notoriously inaccurate. For starters, they are magnetic field sensitive. I can use mine as a compass and it is one of the best available. They all get real bad at the low ranges.
The reading of 70 amps for a 6.2@120VAC is about right. And, yes, it will toast your little Grp. 24 battery. I am not surprised that inverter put up with it for a while, but that while will be a thermal limit for the hardware.
Matt
