bounder39zman
Aug 02, 2023Explorer II
I have used the "Slick Stick" a bunch. worn a couple out. If the slip rings are only slightly oxidized/worn you can clean them. I usually cut a piece of green scotchbright pad to fit end of a paint stir stick or chopstick, tape it on with elec tape. This works well on older Emerald, Marquis, and newer 5.5 and 7 kw sets. Just remove brush block for access to rings. You dont specify what model of 4K Onan you have, but likely a 4KY Microquiet. the brushes are behind fan/flywheel and will require some disassembly to access brushes on this model
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
