wny_pat1's avatar
wny_pat1
Coleman 7333 Air Conditioner Height
Anyone know the actual height for roof to top of a Coleman 7333 13.5 BTU air conditioner. Not the shroud, but the actual A/C, minus shroud, height.
It isn't in the manual, cause I looked!!!
Need a new shroud, and it looks like all the replacements are going to be 3/4" short.
  • Thanks Doug.
    Am wanting to put a Icom Direct replacement shroud on, but it is only 12 3/4" high from roof, while the Coleman is 13 1/2". Icon says "If the height of your air conditioner is about 12.75 inches then this shroud should fit perfectly. If your air conditioner is taller than 12.75 inches then the shroud will still fit, but the bottom of the shroud might not sit flush on your roof." Would like to use the Icon shroud as it appears to be of better quality, but don't want it sticking up 3/4" from the roof.
  • RVP has gone to a universal shroud. The P/N is 8335-A5261 and will fit your old 7333. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
