Coleman Mach Air conditioner fan problem???
jolooote
Hi all. 2015 Thor Vegas, 15K BTU AC. All worked B4 I started work. Just got done cleaning the roof Ac fins. Removed roof plastic cover, Removed tin sheet metal cover over the Evaporator? fins. Cleaned em. Put all back together. Now, got nothing when indoor thermostate is on FAN, any position, Auto, Manual, Fast or lo. But, When in the AC position the fan runs in only the LO position. The compressor runs in both Lo and HI. WHAT have I done?:?
Shoulda listened to my dads advise. "If it ain't broke ...DON'T fix it!"
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
10 REPLIES 10
DFord
If you fixed the problem by "wiggling" the wires, expect it to return.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
jolooote
Yep, wiggled those wires, works now.
Joe & Charlotte
wa8yxm
First on Colemans you do not need to remove the sheet metal cover to clean the condenser. Colemans suck so the crud collects on the OUTSIDE and all you need remove is the outer shroud.
Sounds like yo knocked a wire loose but how you did that I don't know as there are no wires near the area you were working on
Check all plugs and connections.
dedmiston
Moderator
Moderator
Moved from Roads & Routes.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
jolooote
Thanks
Joe & Charlotte
cavie
This should be your first clue You disturbed some wiring at the A/C. Got water into some connections? Knocked some wires loose?
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
DFord
Whether the fan runs or not is controlled by a relay. It probably has a center off position and either switches to high or low depending on what's selected on the thermostat. I could be more help if I knew the brand/model of the a/c so I could find a wiring schematic.
Don Ford
jolooote
opps, I'm in 'Roads and Routes'. Thout it was Tech. Issues. Sorry.
Joe & Charlotte
Lwiddis
โ€œShoulda listened to my dads advise. "If it ain't broke ...DON'T fix it!"
Nope. Maintenance is important and necessary.
newman_fulltime
Look at the box where the filter is sounds like you knocked a wire loose
